Originally posted by Tim The Grim
View Post
Originally posted by redlee View PostBack when things were made properly 3/4 HP Black and Decker grinder.
Runs quiet and smooth like babies butt.
- Likes 1
I picked up a pocket flashlight. The Fenix brand E18R model is not much to look at. It's 2.3 inches long, black with copper accents. It includes a rechargeable 4.15v 700 mAh lithium ion battery and a cable to charge it while it's in the flashlight from a USB source. The light has low (5 lumen), medium, high and turbo (750 lumen) mode. It's expensive, running around $65, but I collect flashlights so that's not out of my range for a "toy".
Just for fun, I decided to check this itty-bitty light against some more conventional ones. Top to bottom, they are a Fenix PD35 (850 lumens max), Ultrafire WF-502B (900 lumens) Surefire L4 Lumamax (100 lumens) and the E18R. The quarter is just for scale. Speaking of money, the brightest rated light cost me the least (about $20) and the most expensive (the Surefire) cost me $160 in 2003. Both Fenix models were under $75.
And then I did some comparisons of the light beams in a totally dark back yard. You get to guess which is which. All 4 pictures were taken with the same settings and the light at the same spot. In all cases the pictures were taken within 10 seconds of turning on the light.
(surefire er18 PD35 Ultrafire ) Note: The surefire did light the fence, but the camera's ISO, aperture and shutter speed were chosen using one of the brighter lights.
DanLast edited by danlb; 12-03-2020, 08:33 PM.At the end of the project, there is a profound difference between spare parts and left over parts.
I had a series of unfortunate events with work so I am only one step away from losing my lucrative aviation career. I am making moves to secure a future outside of aviation that will make liberal use of my home machine shop, and just decided to cash out ALL of my vacation time to be used for investments.
The thought of this actually makes me feel happy.
Originally posted by RB211 View PostI had a series of unfortunate events with work so I am only one step away from losing my lucrative aviation career.
DanAt the end of the project, there is a profound difference between spare parts and left over parts.
Originally posted by Bob Engelhardt View PostAnybody see my chuck key? I looked where it should be, I looked where it could be, I looked where it would be. I'm about to start looking where it couldn't be.
- Likes 1
Moving things around in the grinding room/woodworking area. Moved all the grinders over against a wall that I opened up by moving about 25 plants to a different area. (We have a goodly number of tropical type plants that come in for the winter, bananas, and various citrus, cactus, and houseplants, plus a coffee tree.)
Not sure I am happy with that, I had originally thought I would ut a workbench there, but I don't have the workbench at the moment. I could build one, but the two old-school workbenches I have just plain spoiled me. They are both ones with steel K-type legs, one of the two very heavy, and they just do not wobble. The heavy one has 3" thick wood top glued up of real 2 x 3 section lumber. I want another one.CNC machines only go through the motions.
I really need to get the ducting for my pentz cyclone, been doing some woodworking and I am running the shop vac which is failing to catch most of the dust from the table saw, so I am running the shopvac and also the dust collector without ducting just as an air cleaner.
