I yanked Doozer's chain a bit...😆
Originally posted by DennisCA View PostDishwasher broke (stopped pumping out waster water, refused to start up new washing programs again after I drained it), spent most of saturday fixing it. Had to take it out and disassemble it. First I thought it was an eletronic error but all the components looked pristine. After that I disassembled the pumps and heaters so I could reach the drain pump, inside that I found a shard of glass wedged in the impeller preventing it from moving, I tested the pump independently and it worked fine so that was probably it.
Reassembled and it started up and ran a test program, it worked! Well the first time I saw it was leaking water, so I had to stop and redo all the hose clamps. Also lifted it on two chairs so I could look under it and watch for leaks. But it ran a program from start to end properly and no leaks.
So now this thing just needs a better filter, pretty crappy filter to let a glass shard through.
Originally posted by rrrgcy View PostOPEN EYES, OPEN EARS, OPEN MIND
Toys for the kids, building a catapult for the kids. I am building two copies to be exact. It's gonna be inspired by the Da Vinci catapult so the turned dowel will go in the center and there will be a ratcheting wheel and trigger mechanism to let it go.
I don't have a wood lathe anymore so I had to improvise using my metal lathe. I think I prefer using it over the wood lathe, at least for making simple parts like this what I want to be perfectly round and consistent. Used a leather to cover the ways and also had dust extraction.
- 2 likes
Originally posted by Cenedd View Post
Back when they made things so they could be taken apart to fix, were fixable and whoever made them didn't die of embarrassment at the state of what you find when you get past the outer layer. There's no pride in 99% of what's made now
I buy two of these at a time for general shop use, bought 2 this July and one still works, one went in the scrap when it failed last month. $22.00 each'
Can't beat it, use them for low priority work, measuring standard fasteners, mill finish stock, rough machining and general measuring.
Why use a Starrett tool to measure hot rolled steel stock?
The people that work in the high end of manufacturing still have pride in the products that they make, you will not ever buy them because of cost.
When they stop working toss them. https://www.amazon.com/VINCA-DCLA-06...54&s=hi&sr=1-6
Thank you China.Last edited by Bented; 12-09-2020, 08:33 PM.
What did I do today? Well the most recent thing was "attending" via zoom, the service for my half sister Katia, who died of Covid a few days ago. That came right after a silly city commission meeting that I was glad to get out of early, but not very happy about the reason I did.
She had just gotten married in August.Last edited by J Tiers; 12-10-2020, 01:35 AM.2801 3147 6749 8779 4900 4900 4900
It's just a box of rain, I don't know who put it there.
