Finally got my air fittings delivered from two different sources - I have up on one and ordered elsewhere since nothing showed up. I want "Euro" ends. In one delivery I got "A Style" ends which I believe you know as ARO style. In the other delivery I got Shrader ends. So I still don't have a complete set of compatible couplings.
For quite a while now I've had one fluorescent tube in an 8' pair not lighting. It didn't really bother me so I let it go but today I decided to see what was wrong. I swapped the tubes and the same side doesn't light up so it wasn't the tube. Next was to open it up and tighten all the connections but it was till the same. Then just on a whim I decided to check all the connections and lo and behold I had swapped the red and blue wires at their connections at one end of the tubes. I corrected that and both worked...but the thing that really has me stymied is why did it work so long wired incorrectly? I replaced the ballast a long time ago which had to be when I miswired it but I KNOW for a fact it was working properly right after I changed that ballast.Location: Saskatoon, Saskatchewan, Canada
Originally posted by Arcane View PostFor quite a while now I've had one fluorescent tube in an 8' pair not lighting. It didn't really bother me so I let it go but today I decided to see what was wrong. I swapped the tubes and the same side doesn't light up so it wasn't the tube. Next was to open it up and tighten all the connections but it was till the same. Then just on a whim I decided to check all the connections and lo and behold I had swapped the red and blue wires at their connections at one end of the tubes. I corrected that and both worked...but the thing that really has me stymied is why did it work so long wired incorrectly? I replaced the ballast a long time ago which had to be when I miswired it but I KNOW for a fact it was working properly right after I changed that ballast.
Originally posted by Arcane View PostFor quite a while now I've had one fluorescent tube in an 8' pair not lighting. It didn't really bother me so I let it go but today I decided to see what was wrong. I swapped the tubes and the same side doesn't light up so it wasn't the tube. Next was to open it up and tighten all the connections but it was till the same. Then just on a whim I decided to check all the connections and lo and behold I had swapped the red and blue wires at their connections at one end of the tubes. I corrected that and both worked...but the thing that really has me stymied is why did it work so long wired incorrectly? I replaced the ballast a long time ago which had to be when I miswired it but I KNOW for a fact it was working properly right after I changed that ballast.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
"There's no pleasing these serpents"......Lewis Carroll
Spent the last 4 days baby sitting a die shop while the owner is away. 8 hours milling, drilling, heat treating and grinding small die sections each day. 8 hours all alone in a shop 34 miles from home and a couple thousand feet from where they dropped those two little girls over the border wall. Border Patrol helicopters flying over so low they rattle the bay doors. BP on horseback and 4 wheelers maneuvering back and forth through the area. Needless to say, I’m packing.
Going back Monday and Tuesday as well. Actually feel like it’s a weekend.
Also, yesterday I got to see the prosthesis that the engineering students put together with some of the parts I machined for them. They had done their presentation on Thursday and it worked well and their professor was very happy. Two boys are graduating and going into jobs and a third is going for his PHD.
I will continue to work with him in the future.
As a show of their appreciation for my help I was given a 1.75 of The Famous Grouse by these fine young men.Illigitimi non Carborundum 😎
Back in the ‘80s and ‘90s I read a series of books by W. E. B. Griffin that had a couple characters who would imbibe in “The Famous Grouse”. All that time I thought it was just a made up name for the books. One night in ‘07, my wife and I walked into a local liquor store and there was a huge display of various Famous Grouse blends at the head of an isle. I was very surprised that it was actually a real brand and bought a bottle of the standard blend. It has since become a favorite blended Scotch.Illigitimi non Carborundum 😎
My friend John found an old electric drill. The cord was badly deteriorated and I cut it off. There were no identifying marks so I have no idea of the manufacturer or age. I had hopes to rebuild it so I took it apart as far as I could, but I was unable to remove the armature or the stator. The end of the stator with the commutator was held in place with a ball bearing that was press fit onto the shaft and into the housing. And there appeared to be no way to remove the stator, which appeared to be cemented or press fit into the housing. The wires going to the commutator and the stator were insulated with rubber, paper, and cotton, and seriously deteriorated. So no hope of fixing it safely. I was able to unscrew the Jacobs chuck and I drilled one of the holes to 1/4" to fit one of my chuck keys
USA Maryland 21030
USA Maryland 21030
