Updated my signature. Doctors app't in the AM (it's 4 AM right now) hopefully this BS will be over soon
Annular bearing bores, 50 each 2.047 +.000-.0015" Dia. X .866" deep in steel.
Then 54 each .8750 +.0000 -.0005" Dia. X .531" and .281" deep on opposite ends of the roller in POM.
A terribly boring way to start a week as you can probably imagine (-:
I have really not had to use Face Mills all that often on tool steel such as A-2. Today I had to knock a 4”x 5” x 3/4 piece of A-2 down to 5/8 thick. I used this SECO 4 tooth insert face mill to do that and was astounded at the performance and quiet operation. I had used a smaller triangle insert 3 tooth a little earlier on a different piece and it was typically clacky while cutting. This SECO unit with octagonal inserts was quiet and actually fun to use on a mill with no table feed.
Illigitimi non Carborundum 😎
Originally posted by Noitoen View Post
You can drill a hole on the center of the back bearing housing to push the armature with a small punch
I have three corded 3/8" drills and a 1/2" corded drill, as well as 3 or 4 working Ryobi cordless drills (plus one with a broken case). And I have several old cordless drills that use NiCad batteries which are non-functional. I just bought two 7.2V NiMH battery packs for my DeWalt power screwdriver that also had defunct NiCad packs. I considered buying 12 NiMH 4/5 C cells for about $25 but the complete new packs were only a couple bucks more.
Maybe I could fix some of my other cordless tools that need NiMH cells to replace their dead NiCads. But I don't really need those tools - I just hate trashing them.http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
Originally posted by PStechPaul View Post
I thought of that, but I'd also need to remove the stator (field). Maybe I'll try that before consigning it to the scrapyard, but it's hardly worth it.
Maybe I could fix some of my other cordless tools that need NiMH cells to replace their dead NiCads. But I don't really need those tools - I just hate trashing them.Helder Ferreira
Setubal, Portugal
- Likes 1
There are no markings showing mfr or vintage. Although I am the "Lord of Lost Causes", this seems genuinely hopeless and pointless. And if I take drastic measures to take it apart enough to fix it, it will lose its value as an historical relic.http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
Originally posted by Tim The Grim View Post
Originally posted by RB211 View PostGetting into CHIA mining, since I think the world demands a greener mining solution, not that I exactly care about that...
Originally posted by reggie_obe View Post
Apparently has nothing to do with Chia pets or Chia seeds....
https://www.techradar.com/news/chia-...matter-of-days
