  • Blanked out a part for the Spanish Destroyer Carbine bolt that I am copying!
    Waiting on a radius cutting end mill to do the finishing touches!
    • This is what I did today. Plywood templates for the windowsills - since they're less square than I was hoping and I didn't want large gaps or the front to be on the slant. Then cutting the stone and dropping them in place. Angle grinder dust shroud was rather janky but it got the job done adequately - not what you'd call a factory edge but not bad and it won't show after a dash of caulk. Still have to chamfer and polish the edge on one - no factory chamfer and polish on that piece unfortunately - but that's a job for another day!
      • Finally I got the new ridge plates this friday. I also made a ladder that hooks over the ridge, which I used to get up there and screw the ridge plates in place. The apex of the roof is about 14 feet or 430 cm
        A few screws left and the roof is done, but I have to move the whole scaffold so I can reach the last bit safely. I got it screwed into the building and attached to the birch tree with a strap for stability.
        • I was planning on buying a nice used car. But it sold before I got to it. I happened upon a decent 12" 3 jaw cushman chuck though. The jaws are a little bellmouthed, but the runout is pretty good. Not bad for $100. I'll try grinding the jaws and see if I can do a better job. They're smooth anyway, I want toothed jaws.
          • DennisCA: I see some paper birch trees there. Nice! I like those.
            Where I grew up they grew everywhere, but now that I live in the "tropics", I never see them any more, they won't grow here. All we have for birch is a dirty-looking tree known as a "river birch".
            4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
            "There's no pleasing these serpents"......Lewis Carroll
            • Originally posted by The Metal Butcher View Post
              I used a boring bar with Carbide Inserts for interrupted cutting to machine these Bison Jaws I Click image for larger version
ID:	1960362 Click image for larger version
ID:	1960363 don’t know if the bolt on Jaws are Harder.
              • Last time I tried that it ended poorly.
                • Dad and I drove up to TN and bought a bed for his new 05 Isuzu. Quite a shakedown run for a new (to him) truck, I think we were on the road for 8 hours. Nice bed. Just what we needed, 11x7.5, steel. The bed isn't perfect. We had to do some ****ty torch work to get it on. Needs to come back off, get some arc gouging and some patching of some holes. Gonna have to cut the rear bumper off as well. Overall a good start though.
                  Truck isn't perfect either. Has some sort of throttle position sensor issue or something. Bucks pretty bad at times and likes to get into feedback loops. Not perfect even with the speed control. But man does that 5.2L diesel pull after being used to the 3.9s. Theoretically almost twice the HP but actually well over double with how poorly his old one was running.
                  He's almost got the '88 back on the road too. Should have two good trucks soon.
                  • Got a 5" 6 jaw Buck chuck that turned out to have a missing tooth on the pinion and a fair bit of wear on the teeth either side of the gap. Plus the key hole was really wallowed out (it's had a hard life I think). I ground out a slot where the tooth was and my friend used his MIG welder to fill in the gap and the keyhole
                    spent some quality time with the Dremel and ground a new tooth, then drilled out the keyhole and tidied it up with a carbide burr.
                    keyhole ended up a bit off center and kinda ugly, but the key fits snugly now, which is what matters!
                    Got it dialed in to a bit under 0.0005" and it appears to repeat to that too, at least at that diameter. We'll see how it does across its diameter range.
                    got a buddy to keep it company too
                    • Birthday party for my boys, turning 8. We had a american bbq theme with pulled pork, smoked chuck, coleslaw and smoked beans & bacon.
                      Baked rolls
                      Smoking
                      Morning after
                      The pork got foiled, wrapped in a towel and thrown in a cooler. The chuck got to keep cooking
                      Chuck finished
                      And the pulled pork, got separate sauces:
                      • wow, that's almost criminal posting that online before I've had lunch (or dinner or maybe even breakfast) Looks fabulous! Hope your boys had a great day.
                        • This is a copy of a RCA 44 BX microphone. Everything is from raw stock, except for some screws. Was used for radio back in the 1940's.
                          The logo ,RCA emblem was a challenge, useing Mastercam X 9 for the art work. Had to scale everything from pictures.
                          • Hey, nice! Looks like the ones at the old radio station, except those had a different paint color.
                            How did you do the ribbon?
                            • I cut to length and ground the bullet noses on 18 1/4” diameter pilots for a progressive draw die using a Harig Grind-All on a Boyar-Shultz 6x12.
                              My left arm and hand are tired and aching.
                              On a different note…it’s very sad that so many companies that used to feed the die making industry with stock lifters, spring kits, bushings etc. are gone forever. Honestly if the poop hits the fan, we’re in it deep.
                              Illigitimi non Carborundum 😎
                              • Originally posted by J Tiers View Post
                                I cheated on the ribbon motor and foil. Was from another ribbon mic. The most used color was umber gray ( beige to me ). So I did the copy in lacquer black. Lots of 44 B's were black. If you are to buy the real mic, it would cost $ 3,500.00. So I just made one. Thanks for looking!
