Bented Nasty. I'm guessing a form tool not as wide as the groove that you can plunge in and then move left? I'm assuming, of course, this is on a lathe.
Originally posted by SVS View Post
Little known fact-Right after he invented the steel plow Mr. Deere invented the twin rotor thresher-NH actually copied Deere first……😁😁😁
Yes lathe work.
These grooves simply keep the ring from falling out,
There is however a round feature that allows the easy installation and removal of said elastomer ring.
The customer drawing says produce the round undercut before the groove is formed, I have never done so in10 years, this causes an interrupted cut using a fragile tool.
Not one single part has been rejected.Last edited by Bented; 07-17-2022, 07:31 PM.
And finished the repair of a carbide boring bar - the insert pocket and threads were almost completely gone, so I built it up with my friends mig welder and machined it back. The insert thread ended up slightly off so I glued in a shim to make up the gap. Still a bit pissed about that, but didn't want to start again
I went on a trip with several of my relatives and family to visit my oldest nephew who is 21 and bought his first home. It was a very nice place IMO.
The main house is from 1880, log house construction, about 160 m2 in size with both floors, there's also a nice basement for storing food & drinks in:
Other side
On the upper floor I found this miniature masonry heater, there's a full sized one at the main floor too, it works by burning hot & clean and then running the flue gasses through channels that help absorb heat into the mass of the heater
I found an actual porin matti in the upstairs bedroom. It's a heater that gives both rapid heating and has a few hundred kilos of mass to retain some of it for a longer period. Once in use that flower could not be there, as the top plate was designed as a cooking plate too. One can see the hewn logs in the background.
The property also includes stables, they have 4-5 horses (other peoples horses)
A second house, this is a guest house / sauna
There's also chickens, rabbits, a few cats on the farm
Several more outbuildings, some fields and a little forest was included too.
Pretty impressive first home for a 21 year old
👍 3
Mounted up the right angle attachment to modify a radius on a scope rail. Range day tomorrow.
We’ve been maximizing time with the grandkids lately, so little shop time these past two months.
The one starts pre-K and the other public school Kindergarten next week.
Empty nesters again after 5 years with little ones.
Illigitimi non Carborundum 😎
It’s an elaborate camouflage of an “oops!”😁
George Bulliss Tim The Grim deserves an honorable mention!Avid Amateur Home Shop Machinist, Electronics Enthusiast, Chef, Indoorsman. Self-Proclaimed (Dabbler? Dilettante?) Renaissance (old) Man.
👍 2
I like blocks. I have lots of 1/2x1x2, 123, 246 and various clamps and tooling to take advantage of them. Drilling and tapping my ( Not a Kurt ) vise allows me to even better utilize those blocks and that same tooling.
Ever since Sister Veritas broke 2 pointers and a brass rail wooden ruler over my hands in 1st grade…( Because I colored the squirrel’s eye blue instead of black ) I’ve been unconventional. This is just another sign of that.
Thanks ChazC.Illigitimi non Carborundum 😎
👍 1
