Actually I lied I made two
Originally posted by ChazzC View Post
Originally posted by Captain K View PostMy new range hood came with a suction cup to install those bulbs. Maybe you can get one for next timeAvid Amateur Home Shop Machinist, Electronics Enthusiast, Chef, Indoorsman. Self-Proclaimed (Dabbler? Dilettante?) Renaissance (old) Man.
Originally posted by ImFred View PostMade a tool for a friend for a black powder weapon.
Don't know why the pictures show up so big on my PC. On my phone they are normal. I loaded them from the phone.
Depending on what you started with Medium usually works, but for screen shots Large or Full Size may be OK (the above is a screen shot and is "Full Size"). You can also choose "Custom," which allows you play with the width & height.Avid Amateur Home Shop Machinist, Electronics Enthusiast, Chef, Indoorsman. Self-Proclaimed (Dabbler? Dilettante?) Renaissance (old) Man.
The Servo on my mill came to me without the gear cover.
I finally decided to do something about it. Being unwilling to sacrifice a piece of stock that large, I determined that 4 in. ABS drain pipe would fill the bill. Starting with a piece about 7 in. long, I first cut a ring. Then I slit the remaining piece lengthwise, put it in the toaster over to soften and flattened it on the welding table.
Off to the lathe for some of what a lathe does best.
et voilà!
It's all mind over matter.
If you don't mind, it don't matter.
- Likes 2
Nice work. On a laptop/desktop you can re-size photos by dragging the lower right corner of the photo (have to scroll to find the corner, and it may take several drags to get it to the size you want). On any device, you double-click the photo to open "Image Properties" and then use the pull-down to change the size:
- Likes 1
CharlieAvid Amateur Home Shop Machinist, Electronics Enthusiast, Chef, Indoorsman. Self-Proclaimed (Dabbler? Dilettante?) Renaissance (old) Man.
We have iron in our water and the water softener removes most of it, but not all of it. So things get stained, including the porcelain dishes. It builds up very slowly, but it reaches a point of no-ignoring. Today I cleaned them with muriatic acid. A 5 or 10 minute soak is all it takes. Longer might make a whiter result, but the dishes aren't pure white to start.
Originally posted by eKretz View Post
Out of curiosity, have you ever tried Bar Keeper's Friend powdered cleanser? I have used it for rust stain removal on bathtubs, works awesome.
