Originally posted by The Metal Butcher View Post
Looks great! How slow does your lathe run?I just need one more tool,just one!
I did that on the Grizz 4003, 70rpm is the lowest, normally I flip the tool and run in reverse so I am feeding away from the shoulder. But this time the only holder I had to fit the 22R4.5 insert wouldn't allow it.
My Sidney runs 20RPM so the fast threads aren't so frightening.
Damn! Big parts for that lathe. I can see how that would be a challenge. Espcially with such a small leadscrew, numbers would be wizzing by if not for being metric.
My Sidney runs 20RPM so the fast threads aren't so frightening.I just need one more tool,just one!
Recently I was trying to make a face mill along the lines of this one:
On the third one, it still wasn't right, but will work. Next was to make a insert holder for my fly cutter, using the same recycling of the obtuse points of worn out CCMT inserts. Not wanting to repeat the bumbling of the face mill, I made a step by step how-to picture-book:
Very useful for this novice mill-er. The tool has some warts & is not photo-worthy, but there were no blunders in its making.
- Likes 3
Made a simple fixture for drilling safety wire holes in socket head cap screws. The hex in the middle is a piece of 10mm hex that I turned a 5/16 shoulder on and threaded 5/16-24 for a nut to hold it into a reamed hole in the fixture. These screws get drilled through in three places in the center of the flats. Once the hex was assembled and timed in the fixture, I drilled and reamed the fixture and the hex for a couple 3/16 x 1/16 drill bushings. With a good split point cobalt drill it didn't take long to drill all 50 screws in this batch.
- Likes 9
HI wierdsience,
The fixture you made that has the drill bushings. Can you explain more about those. I had not heard of such a thing and I need to do a similar fixture for 1/4 x 20 bolts for a project. I have taken a hex nut and installed it like your allen wrench piece.
TX
Mr fixit for the family
Chris
TX
Chris
TX
Chris
This is why this forum and the people here are so awesome. Willing to share your knowledge and helping those of us less knowledgeable to be able to learn from your years of experience and talents..
All I can say is thanks for sharing..
TX
Chris
Originally posted by DennisCA View PostI've been wanting to dry my shop air for a while but never considered dessicants, was thinking of using an expansion style system instead. But how often does the desiccant need drying? Do you have to remove it and dry it or is there some easier method?
Originally posted by Bob Engelhardt View Post
Not pretty, but does a great job sucking swarf out of the slots (and the nooks & crannies around the vise or other working holding setup).
- Likes 1
- Likes 1
