Originally posted by vpt
View Post
Con: It's been stressed beyond yield once since it is permanently bent. If you do that again to get it straight, you probably will end up weakening it. And you likely will not get it perfect, leaving a stress point in it. The kink is not a big one.
Pro: If you leave it as-is, it has a definite stress point, because the one leaf will take all the stress right at that kink until it lays flat on the other leaves and they begin to take some. Might end up breaking at the point where it is kinked. If you bend it back so it lays against the others, then there is no special stress point there anymore.
Best idea may be to replace the leaf. Second best may be to get it back into the correct curve, if you can. Kinked springs of any type never seem to be as good as they were before they got kinked. And that one will take a lot of flexing
