Welded up rectangle with angle iron from salvaged bed frames on the 4 sides and some sheet steel from an old night stand, bolted some casters to it and it became a generator cart. Taught my step son (10) to plasma cut and spray paint on this one.
Bought a broken porter cable 5cfm 4gal portable air compressor for $20. Ended up only needing (so far so good) a pressure guage and a female QD. Did a home hydro test on the 2004 dated tank with a grease gun. I still cant figure out what its story was. All the oil from the pump crankcase was pushed through the system to the air tank. Maybe it was stored upside down, and then started?My recommendation?
No matter what I tell you, get a second opinion.
Originally posted by wombat2go View PostHi Matt,
Thanks for the details and photos of the hubs.
I am interested in all things hub as I am upgading a trike hub to adult size.
I think better to reinforce all of the male spline teeth like you did.
If the outer female spline is a floating fit,
the contact face of each aluminum hub tooth will have a cyclic force,
peaking as the tooth comes up to the tension side of the chain.
( that is, the driving force from the chain is eccentric as seen by the hub)
That cyclic load might be why the aluminum chews away in the commercial design.(?)
http://bbs.homeshopmachinist.net/thr...10#post1193510
we'll see how they hold up over time
Another day late comment. Saturday and Sunday I worked in the shop trying to get a little caught up on custom mold jobs. While molds were cutting on the CNC machines I installed some rollers in the short arms of this welding table.
https://youtu.be/bZq9G8mKKdw
By mid day Sunday I knew I was going to need a day off, so I called somebody who had hinted they wanted me to invite them to go fishing. We did ok, and after that they invited me to go shoot some birds in the afternoon. He and I limited out on birds, and his father would have, but he stopped after we limited I think just to be polite. He was only a couple birds short, and we had plenty of time and plenty of fliers. If that interests you then: http://yumabassman.com/forums-new/in...ic,9499.0.html
Today its back to work. Have a couple molds to get done for a BSA troop to cast pinewood derby car weights, several molds on the bench that need to assembled, and or tested, and atleast a dozen custom proprietary molds on the jobs board that still need to be designed and laid out.*** I always wanted a welding stinger that looked like the north end of a south bound chicken. Often my welds look like somebody pointed the wrong end of a chicken at the joint and squeezed until something came out. Might as well look the part.
Been working on my auction press this is the video where I started on press shaft.
https://youtu.be/INyFl_tTZxM
Been having trouble with WiFi being delightfully unreliable - think there's something causing interference but can't find out what. So I finally got round to running a Cat5 cable up to the loft so that the music streamer that runs the bathroom speakers (last year's birthday gift to my wife, who loves a bath) doesn't splutter to a halt.
A day of swearing, overheating (500W halogen in a confined space), cramp, splinters and crawling around in glasswool. I just have the best ideas sometimes!
Will try running the WiFi from the loft next. See if different location and an overkill antenna helps!
I made a quick lathe chuck key adapter to work with a drill. I can only do half turns with a regular chuck key because of the cabinet so wanted to speed things up. The chuck is a new Pratt Burnerd so it is stiffer than I ever will be again. I made the adapter loose so it will fall out before the chuck makes a half a turn for the forget the key in the chuck police.
Originally posted by Ridgerunner View PostI made a quick lathe chuck key adapter to work with a drill. I can only do half turns with a regular chuck key because of the cabinet so wanted to speed things up. The chuck is a new Pratt Burnerd so it is stiffer than I ever will be again. I made the adapter loose so it will fall out before the chuck makes a half a turn for the forget the key in the chuck police.Location- Rugby, Warwickshire. UK
Originally posted by Mark Rand View PostMight be worth removing a fair amount more metal so that you end up with a hex shaft that fits directly in the battery drill chuck. That way you dont even have to think about it.
https://www.harborfreight.com/hex-dr...-pc-68513.html
-jsThere are no stupid questions. But there are lots of stupid answers. This is the internet.
