Photobucket Uploading Problem !!!
  • Photobucket Uploading Problem !!!
    I was just starting to get used to this photbucket....... Now I can't upload any pics. When I hit the big blue upload button the whole page freezes, have to cntrl/alt/delete and end task to get out.
    First time this has happened. Anyone know why??
    TNX...... JL..............
    If your browser freezes it sounds like it's in your computer.
    ...lew...
      Have you tried to use "Disk Cleanup"? That seems to cure most problems with my computer.
      Outback
      So much to learn, so little time
        I ran a similar program and no luck. Everything worked fine the other day.
        JL..............
          Joe, I've had the same problem.
            I wonder if it's related to the site. This just started today.
            JL.............
              PB is OK
              I just tried up-loading a file to my PB account and all was fine.
              Are you on the "free" list account - where there are limits as to the number of images/videos and band-width that you can use. But PB usually warns you about that.
              PB has been a bit "different" lately as it seems to change its sequences or procedures without warning - but I get to expect and accept them and work my way around or through them - then all is OK again - until the next time.
                I'm on the free account, haven't even come close to the limit yet.
                JL...........
