Added capacity for my Sherline mill
  • Added capacity for my Sherline mill
    I needed a bit more room to swing a mount for a winch motor while using the rotary table on my Sherline mill. The piece was hitting the track on the vertical column. I made the spacer blocks shown in the attached photo to raise the column and move the mill head forward.
    It gives me the added room I needed without sacrificing rigidity.
    Holes in the bench below the column allow me to install or remove the block without moving the base of the mill.
    Roger
    [This message has been edited by winchman (edited 10-31-2003).]
    Nice job Roger. I would like to test drive the Sherline equipment some day. Small machines fascinate me.
      Cool
