Can I get Morse Taper adapters apart?
  • Can I get Morse Taper adapters apart?
    I use a tailstock drill with a MT2 adapter (J33 on chuck end, MT2 on tailstock end).
    If I add a MT3 - MT2 adapter to use it on a MT3 spindle, will I be able to remove this adapter easily or is it going to be a nightmare?
    Suggestions, if there are any, to ease the removal.
    The adapters have a slot at the small end that you put the correct size wedge in and smack it with a hammer to separate them. You can buy the wedges and adapters from Enco.
      The MT adapters should have knock out slots so you can use a wedge if you need to separate them.
      Edit: not quick enough with my typing
      regards
      3t
        If the 2 to 3 mt adapter has a tang slot, removal is easy.
        If it has no tang slot, and is more like a tapered bushing,
        I have used a pair of crescent wrenches creatively to get
        them apart.
        --Doozer
        DZER
          If the adapter does not have a tang slot you can slot a tapered fallers wedge and drive it between the back of the chuck and the adapter. works every time.
          Ernie (VE7ERN)
            If your spindle is hollow, a lathe spindle for example, you will be able to knock the adapters out easily enough by poking a broomstick or some such in behind and giving a tap.
            If you have the adapters out but the MT3 is stuck on the MT2 all you need to do is put a bar in hole in the end of the MT3 adapter and giving it a tap, or maybe knocking the ensemble of bar and adapters on a solid surface.
              If you have a slot in it , you can use one of these. They work great and you only need one hand to use it.
              http://cgi.ebay.com.au/SEMI-AUTOMATI...item5190e66f82
              Davo
                This?
                https://www.machineryhouse.com.au/Pr...stockCode=D401
