Milling
  • Milling
    Need help
    I got a milling attachment and some milling tools with my 10" Atlas lathe.
    Can someone tell me what I need to buy so I can use the milling attachment in the furture? Thank you for any help.
    Kenny
    It is called a Draw-in collet chusk Attachment. Do I need one to hold my milling tools?
    [This message has been edited by Kenny (edited 11-05-2003).]
    I think we need more details; what do you think you might need? You've got the attachment; you've got some cutters. What else?
    If you're just unsure about using the attachment, you might pick up a copy of "The Amateur's Lathe," by L.H. Sparey. I'm pretty sure that talks about using a milling attachment on a lathe.
    Realize that it's only for small, light milling. The setup isn't rigid enough for anything else.
      Find "Milling Operations in the Lathe", by Tubal Cain. It is invaluable. It will guide you to satisfaction. Workshop Practice Series #5
      [This message has been edited by Evan (edited 11-02-2003).]
        Powered cross feed is nice. Have you one? If not ask for more info.
