Indexer for shaper
  • #16
    If the fixture holds the gear blank above the cutter there's no limit to diameter. Things can get a bit awkward, though. On my Atlas shaper with the blank below the cutter in the conventional mode the diameter is equal to the distance between the cutter and the table.
    • #17
      Hi Michael.
      The swing on the indexer is just over 4". It is slightly larger than the original Ammco unit.
      In theory I could separate the headstock and make a riser block mounted to the table and make larger gears. But that would entail another spindle with say, a chuck mount. Which means I would never get around to actually making anything! I would rather set up the R/T as Bill has done.
      Geoff
