Just joking Evan.
Still related to stepper drives, being a big hammer man and not understanding the fine points of things you can't see like electronics causes me to ask these questions.
A lot of electronic design can be mimicked by fluid and air designs, after all electronics only controls the flow of electrons.
Now in pneumatic and hydraulics if I want to control a large force I can do so using signal systems.
A 5/3 valve is a good example, I can feed this 40psi on low volume small pipes to open the valve to drain lake Erie.
Now my question.
Why can't a small simple stepper drive like Evans [ hence the hi-jack
] or a Xylotex be used with amplifiers to control hi voltage, high amperage drives?
It's done with audio is it not, weak signal in, large output.
Now my question.
