morse taper adapters
  • morse taper adapters
    I'm in need of some additional morse taper adapters/sleeves.
    There are hardened and ground throughout and hardened tang only adapters available, which should I look for and why?
    They're for a Buffalo #22 drill press and 13x40 lathe..
    thanks
    Mark
    offhand, Id wager a harden taper will last longer, but a soft taper will be less likey to damage your spindle in a 'whoops' event.
