cutters
  • cutters
    found a couple of real nice milling cutters at the scrap yard.....one is a 10 insert the other a 12 insert....Sandvik.......well ran the numbers......no such animal.......guess i will use them for paper weights.......its a shame that Sandvik discountinues its products and make you buy new.......seems like a waste..................Larry
    Could very well be custom jobs.
      cutters
      the numbers get close...but dont match anything in there catalog................i would like to find inserts for them so i could use them............i guess my find was to good to be true................luckly i did pay anything for them................yard just said "take um"
        Try the numbers straight into Google or with site:sandvik.com afterwards (I know this isn't the correct site address, but hopefully you get the drift).
          i went right to the Sanvik site and had no luck............is it possible to match up the insert without having a number..............i hate to totally give up on these.....
            Try looking at the Sandvik website in earlier incarnations using the Wayback machine, you might be able to find your cutters that way and identify the inserts. http://www.archive.org/web/web.php
