I think it's rated to drill 3/4" holes in steel and this is all I have in the way of machining tools with some drill bits 200 rpm is the lowest speed. I'm making a set of wheel spacers for my tractor and need to counter bore 11/16" diameter and maybe 3/16" deep for the wheels headed M14 studs. The heads need to be recessed. Is there a counter bore drill or do I try to grind down the 60 deg. 11/16 drill to a flat cut profile? bjr23
16 Speed drill press-all I got
This will show what is needed http://www.icscuttingtoolsinc.com/catalog/page_182.pdf It is possible to grind a drill bit that will do the same thing.Last edited by portlandRon; 04-14-2010, 04:27 PM.
