Step pulley size standard
  • Step pulley size standard
    I am looking to replacement 4 step pulley for A/4L size belt.
    I've checked online drawings of 4 step pulleys from different manufacturers.
    The height(marked as letter "F" on the drawings below) of similar 4 step is slightly different between manufacturers.
    I wonder if the distance between pulley groves is also different between manufacturers. If it is the new pulley might not match with my old pulley.
    http://www.clesco.com/congress/produ...e_pulleys.html
    http://www.maskapulleys.com/Images/p...ep_pulleys.pdf
    Thanks,
    Alex
