Need help: Idler pulley on a shoulder bolt..
  • Need help: Idler pulley on a shoulder bolt..
    My problem is I need to hold the pulley out away from the body of what its bolted to..But that leaves lots of room for the pulley to slide on the shoulder of the bolt.
    The only idea I can come up with is to put a piece of tubing to act and as a stand off....
    Any other ideas?
    Thanks
    Stepped washer.
      Rubber tubing, steel sleeve, washers as a spacer, nothing wrong with that.
