making a lathe mandrel
  • making a lathe mandrel
    I have a couple of questions about making a lathe mandrel or morse taper. First, is O1 rod a decent choice of material? Second, Do I turn the shaft to size, then harden or do I leave some room, harden the material, then finish to size. If the latter, can I finish with HSS, or will it have to be carbide?
    Thanks for the guidance.
    I would recommend 1144. I think it machines better than O1 and one can get an excellent finish with either carbide or HSS tooling.
    Just finished a spindle mounted ER25 collet chuck using 1144 and have decided that it doesn't need to be hardened as I am in HSM mode.
    Geoff
      If you harden it you will need to finish it by grinding or use an insert made for hard turning. Neither HSS nor standard carbide will work.
        Thanks, that answers my questions.
          Now that's a Mandrel
          Came in at work the other day from one of our suppliers
            Whats a special hard turning cutter? I've always used carbide or a grinder.
              CBN, also available in the shape of carbide inserts. But they are a bit pricey.
              Nick
                Nick
                And don't even think about an interrupted cut OUCH
                  There's a geometry for interruped cuts available. Works up to 60 HRC. ISO-code "CBN 725 T".
                  But I have no experience.
                  Nick
                    How long a mandrel, what diameter, what sort of lathe do you have?
                    What sort of accuracy do you want..
                    Precision takes time.
