threaded center punch?
  • threaded center punch?
    What do you call them and where to buy the threaded center punches.
    I need to make a flange and it would be useful for me to have these short punches to thread into the hydraulic motor flange and then put that on my plate to mark the holes exactly. I have seen them used before but can not find them online. Also some dowel pin gauges would be good but can not find them either.
    Try a search for transfer screw sets. You can find what your looking for at Enco or MSC.
      If you can't find them , it sure wouldn't be hard to make some. Just turn a point on some short bolts or thread some rod and and taper the end.
      Hal
        Thank you, That was what I was looking for!
