magnetising milling table
  • magnetising milling table
    hi, i want to attach a splash shield to my milling table using magnets. but am afraid to magnetise the whole table. there would be 7 - 9 23 kg magnets. does anybody have any experience?
    guard
    Why not just make brackets that clip into the T slots. Then you wouldn't have to worry about chips being attracted to the magnets.
      If the table is cast iron, you won't permanently magnatize it.
      K Liv
        no chips on magnets, they would be on the sides of the table behind the shield.
        tried it out today, works perfectly, easy to put on and remove.
        so i wont magnesise cast iron, but what about the vice, dividing head, clamps, indicators?
        i hear/read about whole shops having been magnetised by strong magnets being around for a longer period of time. neodyme are succers.
        what do you think?
          Post a picture!
          We want to see your splash shield
            the shield is somewhat invisible, but you can see the magnets. theres 8 of them.
              You could reduce the stray magnetic field (and hence the tendency to magnetise all and sundry) by fitting the magnets inside iron or steel 'pots' (i.e. a pocket) with a non-magnetic (Al/brass/copper) spacer around the magnet . This will concentrate the field to the open/table end. You may also find you could get away with smaller magnets this way.
              Bill
              [edit] like Frank Ford's pick-up device here:
              http://www.frets.com/HomeShopTech/Ma...ickuptool.html
                For what it's worth, I use neodymium magnets all over the shop - to hang notes, tools, shields, and for setups. Never had a problem with accidentally magnetizing big stuff. Small things like parallels can start to attract chips, but I just demag them like I do my other tools as needed.
                Near the top of this page there are a dozen more uses:
                http://www.frets.com/HomeShopTech/hstpages.html
                Frank Ford
                HomeShopTech
                  concerning the "steel pots": so it doesnt really matter how thick the non magnetic insulation is?
