Cork Gasket under Headstock Cover
  • Cork Gasket under Headstock Cover
    I would like to remove a cover from the top of a Jet headstock to inspect
    for casting sand and manufacturing swarf, but I am wondering what
    the prospects are that a cork sealing gasket may be damaged during
    removal.
    50/50 unless the gasket is no longer available then 100%.
    You could use silicone gasket for a replacement or to repair a simple tear in the cork.
      >> 50/50, unless the gasket is no longer available, then 100%.
      Ah, one of life's universal truisms.
      It has been a good day. I think I'll leave well enough alone for tonight.
        I've had good success on two accounts, it seems that gasket serves more to keep crap out then the oil in.
        Agreed, late night is not a time to "start" much of anything.
          It's really just a swarf blocker. A replacement can be quickly made with a sharp blade and a sheet of gasket stock, or as mentioned, the original repaired with a dab of RTV silicone. Have a look, scrape your sand, repair as required, and move on my man.
          Paralysis by analysis.
            Tap and cut
            If its just to keep most of the oil in and all of the "shop gunk" out, then make a cardboard gasket - "Manila" folders - as used in older paper file storage cabinets is just fine.
            "Tap and cut" it out with a small ball-pein hammer - holes if necessary can be cut out or finished with a "wad" punch.
