A proper ring for a machinist.
  • A proper ring for a machinist.
    Found this on the net.
    Seems like it would be appropriate for a machinist to wear, eh?
    Interesting ring for a nervous person.
      Oh great fun when your skin gets caught up in the gears. Definitely don't scratch nothing when your taken a 'Tiki' in the morning
        don't sneeze without a handkerchief
          I wear a really cool titanium wedding ring and I tend to play with it a lot. That ring would cause OCD.
          Bob
            That's cool. Just don't wear it around rotating equipment.
              It IS rotating equipment.
                I like it wish I had one.Alistair
                  How do you think it's held together so that it rotates without pulling apart? I saw one small grove on the inside. Those would have to some very short screws holding the pinion gears. That is a pretty neat ring.
                  Ted
                    I believe the screws hold not only the pinon gears but also two machined halves together - I think the screws are shouldered.
                    They need to show it stuck in the guys GF hair --- I don't like the way the end of the pinons hang out around the radius --- one of the outer ring drives should be fitted with an O-ring so the stooge that buys it can at least roll it along his desk and amuse other stooges, big improvement over having to "hand jog" the GD thing...
                      Which hair?
                        I wonder if you could rig up a power feed on that thing......
                          Yep, screws extended into grove. I didn't my thinking cap on tight enough.
                          For $165 dollars, you would think it would come with at least a grease fitting.
                            Ah. Game over. Hard to imagine wearing it. Everything would get caught in it. Maybe even the wearer's hair. Ouch.
                              I couldn't make it for $165.00. Not that I'd want to. It's pretty cool,though.
