Horton universal chuck
  • Horton universal chuck
    Acquired one of these this last weekend
    it's a four jaw and a scroll chuck, all in one ..
    it has a spring loaded peg sticking out of the back ..what's it for ?
    the other locking devices at the back, Ive worked out .
    it's quite good condition ..no rust..just needs taking apart to clean it ..
    any tips appreciated..from what i can gather on it ..says patented in 1873..so maybe over 130 years old
    says CONN USA on it ..so i thought you guys would know a bit more
    oh, has small chunk missing out of one of the jaws ..would it be OK to weld this ..
    all the best.markj
    Are you forgetting something??? No pic means it didnt happen!
      alright ive put the cam batts on charge .
        I would NOT weld the jaws if you do not have the capability or intention to completely regrind thier clamping surfaces true to the chuck again
        (ie the inside and/or outside of the jaw faces, And possabley even the 'ways' in the jaws)
        You don't want heat distorting them.
          its only a little nick 2 second burst with the mig..and because weld is soft, i can true it whilst its spinning in the lathe ...or even spend a few seconds fileing it
          all the best.markj
            as it came ..no clean up
              Ooo, she's an oldie. those exposed tightening nubs went away for a reason.
              This might be a good candidate for electrolytic rust removal.
                took it apart today cleaned it, lubed it with dry moly..and gave it a spruce up
                all the best.markj
                  I've seen 3 jaw chucks with those features. They were also quite old.
                    Seen a Schunk?
                    They're wild: http://tinyurl.com/schunk
                    BW
