Involute shaft
  • #61
    Brilliant, that three tooth bit. The ones that I have made only have a single tooth with the hole offset a bit to provide clearance. I will have to give this cutter a go the next time the need arises, ought to be three times as fast.
    -brian
    Hello, my name is brian and I'm a toolaholic.
    • #62
      Yes, Brilliant! But i'm not impressed. I've grown to expect as much from you, JS. I suppose you kept your local pub busy for a spell after completion?
      John M...your (un)usual basement dweller
      • #63
        No I got dragged screaming and kicking down to Asda [ Walmart in the US ]
        Still managed to sneak two packets of fig rolls and a big bag of pork scratchings in the trolley.................
        Pub tomorrow night, and Wednesday and possibly Thursday if my new breakout boards are ready.
        • #64
          DT
          Nicely done all round John.
          That should well and truly skewer a few Doubting Thomases.
          • #65
            I don't "doubt" a damn thing, Ralph. So I'm safe from "skewering".......
            It's a good idea... make fewer edges, and you need fewer reliefs..... compromise between hassle and speed of cut, and there you are. It's an extension of one of the ideas in the Goodrich book.
            One would probably top out at about 5 edges doing this, more is a hassle, might need a smaller button cutter, and likely has no real advantage Three is a good compromise.
            2730
            It's just a box of rain, I don't know who put it there.
            • #66
              Beautiful job John! That's the first time I've seen an amateur cut an involute spline. But then again, you're hardly an amateur
              And the finished cutter after hardening but before grinding, sorry about the crap shot.
              Question: why not cut-out the relief slots before hardening?
              • #67
                "If the width of John's cutter was equal to the circular pitch of the gear/spline wide it might have been one of a set of ganged cutters mounted on and keyed to a common arbor"
                I don't think that even with ganged cutters made by John's method it could be considered as hobbing. The shape of the 'hob' would not be correct.
                What John has done is show a really clever (simple) way of creating a relieved form cutter with good enough accuarcy for most of us. Definitely one to keep.
                Bill
                • #68
                  Correct.
                  A hob has straight sides that generate the curved involute, my cutter already has the curve generated by the buttons. Ganging some up would do nothing at all.
                  The offset method isn't new, as I said earlier Don Unwin used a similar method that was in ME in the 60's, 'my' method just takes a few steps out to make it easier.
                  Lazlo, the relief slot were cut before hardening it was the final grinding I was mentioning, just a lick on all three faces freehand after hardening.
                  Anyway, all 10 shafts done and dusted.
                  And will be on their way to Spain tomorrow.
                  Got to be one of the hardest seven pounds eighteen shillings and seven pence I've earn't this month so far.
                  The cutter stud up to the job remarkably well and other then the initial quick lick on the grinder it did all 10 with no problems.
                  Just thought this would help for any quick and dirty gear cutting jobs that may arise where you don't want / need / afford [ delete as necessary ] to get a cutter for a one off or in my case a cutter that is next to impossible to buy.
                  • #69
                    My balls-up
                    I sure got that 200+% wrong and should have known better - I did - but I would insist on bull-$hitting and not only painted myself in a tight corner but also dug myself into a bloody great hole - and kept digging.
                    The "hob" would not only have had to have straight sides but would need to have been spiral cut as for a screw thread but with a transitional circular pitch equal to the circular pitch of John's job and cut on a relieving lathe (Eureka device??) with a pitch modified by the Cosine of the "thread" helix angle etc. The cutter in use would have needed a universal mill tilted for the cutter helix angle and with a universal dividing head geared/connected to the cutter arbor etc.
                    My complete cock-up.
                    Silly me.
                    My apologies - as I don't want to distract further from John's excellent work.
                    • #70
                      Fit.
                      John.
                      Congratulations on a really really very nice job and demonstration of Ivan Laws book (amongst others) "button" method of making a cutter to make a gear or a spline and then showing that it works.
                      As a matter of interest, did you have a chance to use the mating part ("female") to test for fit or did you just have to go ahead anyway?
                      I was interested to see just how well it went as regards "fit".
                      I hope you don't get paid with a Spanish Bank cheque as their banks got themselves into a bigger hole than I dug myself into.
                      • #71
                        JS
                        Nicely done , there is always an other way to skin a cat.
                        did you have a mating part to check to? & did you verify over wires?
                        reiterate liked you post very much. keep up the good work.
                        very impressive.
                        Cheers
                        Lee Miramontes
                        • #72
                          No mating part, I asked for one but it appears it weights 80 tonnes and is in Spain so took a measurement over two teeth, side to side from the pattern.
                          These are not a super critical part, they have a 3/8" drive welded on one end and are used to wind a part out for inspection, they are not a drive shaft.
                          • #73
                            Hobs
                            Just wanted to add that a hob is basic worm it can be Threaded just like a thread. & if it has more the one start it can be calculated like a helical gear, if it a single start then it has to be calculated as a worm. just other options
                            By single pointing or by thread grinding, what needs to be calculated is the
                            lead angle, thus then the "helix angle" 90 deg - lead angle = helix angle, & the pitch, and so on. One way the hob can be measured is by measurement over 3 wires or 2 wires depending on the calculation. the same gear wire can be used.
                            any way for mfg this one way it can be done.
                            Cheers
                            Lee Miramontes
                            • #74
                              JS
                              Gear shops will use spline gages for a go & no go if cost permits , or a sample spline cut internal" in this case", there is a way of calculation a 2 wire check "since a spline has a truncated adddendum, " on gears a 3 wire check can be accomplished. what this does is tell you if the spline involute is correct as cut.
                              spline gages are functional part which will allows for all errors on a spline.
                              for example, lead (parrallel error), involute error, & index error.
                              depending on the # spline teeth, DP & PA the index, lead , & involute will very.
                              a good general for Hobby work these errors will work .0015" max index error
                              .0005" max lead error. involute .001" max, or better yet if it fits the mating part
                              Keep up the Good work JS & thanks for sharing your information.
                              Cheers
                              Lee Miramontes
                              late night fubar my postm, re-edit to fix my poor writting. senior moment.
                              • #75
                                Ill add my compliment, Nice job John.
