High temp adhesives
  • High temp adhesives
    Every now and then some one asks about a high temp adhesive and I came across this site on another forum and thought I would pass it along.
    http://www.cotronics.com/vo/cotr/index.htm
    Pretty slick stuff, they have a whole lot more materials then just the high temp adhesives, ceramic paper, and other insulating materials.
    thanks
    Glen
      J.B. Weld will stand something like 600 degrees,IIRC. We sometimes use it to fill in little holes,etc. on models that are to be cast into vulcanized rubber molds.
        Unless you use it to seal a seam in a radiator, head tank to tubes, then it will last less than a week.
        North Central Arkansas
