Cast Iron for sliding surfaces
  • rowbare
    OP, Is using adding a layer of turcite an option? That would take care of much of your wear issue while reducing friction.
    bob
  • pcarpenter
    Sorry about the late reply. I barely have any time to read here lately, much less post. Here is that page from a Monarch ad. I am pretty sure I found it from someone else's posting either here or on PM, but I can't give credit because I don't know who it was.
    switch_body(0);
  • oldtiffie
    Oil
    I'd be more concerned about machinability, ability to scrape if needed and probably most importantly, lubrication - depending upon speed and load - or perhaps an auto/self-oiler?
  • Robin R
    It might be worth using the Ni-resist for one part and a softer grey cast iron for the other part.
  • wierdscience
    Definately one of the greys,don't remember which,but the more graphite the better.
  • BobWarfield
    Originally posted by lazlo
    I have a copy of the American Machinist article that someone posted on PM where they're hardening a Monarch leadscrew by lowering it through an inductive coil and right into a vat of quench oil.
    Quality indeed!
    Isn't it a pity the Internet and cheap video didn't exist back then so we could see all that work being done?
    It would be fascinating stuff.
    Best,
    BW
  • lazlo
    Originally posted by pcarpenter
    Are you going to scrape these sliding surfaces to flatness? If so, think twice about something really hard...you will curse yourself forever.
    Good point! If you pick the Ni-Resist, you'd better plan on surface grinding it
    I have a picture somewhere from Monarch sales literature where they demonstrate the characteristics of the iron used in their castings, by making a "spring" out if it and then bending that spring into a U shape. They take a round bar of the stuff, cut what would appear to be highly pitched square threads on it and then bore out the center till it looks like a spring made of flat wire....and it bends without breaking. This, to me, implies that they must have been using some variety of ductile iron.
    I'd love to see that Paul. I have a copy of the American Machinist article that someone posted on PM where they're hardening a Monarch leadscrew by lowering it through an inductive coil and right into a vat of quench oil.
    Quality indeed!
  • pcarpenter
    Additionally, the rule of thumb for sliding way surfaces is that you can make one side hard if you want, but you never do hard-on-hard as it leads to galling.
    I can't really answer your question overall since I don't know that a lot of machine tool makers publish the specific grade of grey iron used. I do know that, as mentioned, grey iron has a higher damping factor due to it's structure than say one of the varieties of ductile iron. That having been said, I have a picture somewhere from Monarch sales literature where they demonstrate the characteristics of the iron used in their castings, by making a "spring" out if it and then bending that spring into a U shape. They take a round bar of the stuff, cut what would appear to be highly pitched square threads on it and then bore out the center till it looks like a spring made of flat wire....and it bends without breaking. This, to me, implies that they must have been using some variety of ductile iron.
    Paul
  • lazlo
    Ductile has about 50% higher tensile strength than grey. Grey has superb self-damping characteristics, which probably doesn't matter for your application. Never heard of the Ni-Resist.
  • Oldbrock
    Thanks bob, I'll file that info for myself too. Peter
  • bob_s
    Go with the Ni-resist as it is a grey cast iron with nickel added, that should increase the wear resistance of the contact surface.
    Nickel alloyed cast iron is used in engine blocks to increase the wear resistance.
  • Oldbrock
    One of the grey's, but I don't know which one. Peter
  • snowman
    Guess I should be more specific. From the durabar website, these are the available grades.
    Ductile
    65-45-12
    80-55-06
    100-70-03
    65-45-12 HRDS
    Gray
    G2
    G1
    G2A
    G1A
    Ni-Resist
    201 Type 1
  • Oldbrock
    Continuous cast would be my choice such as Durabar.
  • snowman
    started a topic Cast Iron for sliding surfaces
    There are a lot of different grades of cast iron. What is the appropriate grade for sliding surfaces? I want to make a couple of dovetail slides, but want to do it right. These will be controlled with an air cylinder and see a lot of strokes, but I don't want to use the now traditional ball bearing slide.
