Ariston Lathe question
  • Ariston Lathe question
    My horse shoer asked me if I wanted his Grandfathers old lathe. It is a Ariston.
    I Googled it and found a couple of ads for it. The lathe is quite small as lathes go and in order to change speeds it looks like you have to change some gears.
    It uses a electric motor to a transmission to the late head stock. He said his grandfather used it to make bolts and screws.
    I checked lathes.uk.co and they don't have this lathe listed. Just curious if I should take it for the fun of cleaning it up and making small parts.
    It looks like a nice lathe. Why not take it? Its next stop is at the breakers otherwise.
      It looks in fundamentally good order and complete. The motor conversion is quite neatly done too. I would say take it and even if you do no more than clean it up it will be a joy to have and to pass on eventually.
