Rotary Table Accessories
  • Rotary Table Accessories
    I recently picked up a rotary table with tailstock and dividing plates.
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=370372023627
    I'll be making all kinds of gears(Spur, helical, bevel, worm, etc). and was
    looking for advice on clamping accessories and a chuck to put on it.(Provided
    that wouldn't be too much for tm mini mill/drill). :-)
    Recommendations would be appreciated.
    Thanks.
    Darren Harris
    Staten Island, New York.
    Put it in water so it can grow to be a 10"
    I hope you don't find the surface to be too small to be functional. Having said that, the first thing I'd make for it would be a tool plate with threaded holes you can bolt to the surface to increase it's usable size.
    In addition to the tool plate, I'd get a 6" chuck to affix to it. I find my 8" super spacer to be unbelievably handy.
      My rotary table has a center hole with a #3MT. I have gotten a three and a four jaw chucks which mount in the tapered hole and I find them very helpful in holding items on the rotary table.
      Bill
      Being ROAD KILL on the Information Super Highway and Electronically Challenged really SUCKS!!
      Every problem can be solved through the proper application of explosives, duct tape, teflon, WD-40, or any combo of the aforementioned items.
        My little 6" Chi table has a #2 MT. I prchased a tiny 2" three jaw for it. Surprisingly useful little gizmo for the tiny stuff.
          I have the same rotary table - good choice. I have a front mounting 6" 4 jaw chuck which mounts directly onto the table via the T slots, and a 4" 3 jaw which mounts with an adapter plate. I also made a 2MT to my lathe spindle nose adapter (with draw bolt) which allows the 3 and 4 jaw chucks from the lathe to be transferred to the R/T without disturbing the workpiece. This is very handy, but if used with the R/T horizontal the chuck needs to be restrained or it will unscrew.
          You said: " I'll be making all kinds of gears(Spur, helical, bevel, worm, etc)." Spur gears are easy. Worm wheels should be OK but will require some thought to get the helix angle right for the worm. Bevel gears will have only a rough approximation of the correct tooth shape and will require some hand filing adjustment, but should work OK for slow, light duties. They would require a mounting for the R/T which allows it to be angled relative to the mill table. A dividing head would be a better choice for these. Helical gears - not quite sure how you could tackle those using just the mill and an R/T.
          franco
            I just went through that exercise my self. I took pictures:
            http://metalworkingathome.com/?p=156
              Turn a pointed spud to fit the R/T center hole. It will allow you to quickly mount the R/T and have it (roughly) centered under the mill spindle. Very little dialing in with an test indicator will be required afterward.
                Well, I was told by most that a 6" rotary table was too large for my mini mill/drill. One person on this forum thought otherwise, so that's what I went with.
                I was also looking to get a 5" inch chuck, but for my mini lathe, but was told by most that it was too big, because I would be able to take full advantage of it's holding capacity and it would put a lot of wear on the spindle of the lathe. The idea was to have the option of switching the chuck from the lathe to the mill/drill when needed.
                So basically I'm torn. I couldn't find a 4-1/2" chuck and I need to be able to hold 4" square stock.
                (Also, it looks like I may need to get a dividing head, because I want to create every type of gear imaginable).
                Thanks.
                Darren Harris
                  I was also considering this. But it may bee too small for my purposes. The inconsistent tapers pretty much guarantee that you'll be spending a lot more than intended to for the same tools you may already have.
                  My lathe's spindle is MT3(with an MT2 tailstock). My rotary table's center bore is MT2. And my Mill/Drill is R8.
                  (An I have a big set of 5C collets).
                  Thanks.
                  P.S.: Recommendations on clamping options for my table would be appreciated.
                  Darren
                    I'm still in the market for a chuck for my lathe that I can transfer to my rotary table. But I'm told that even though a 5" chuck would fit, it would be too large for my 7" x 14" mini lathe.(I would like a chuck that could hold a 4" square plate).
                    For the rotary table, I assume that I can easily mount a chuck that has an MT2 shaft, but those are small chucks. And I definitely wouldn't be able to transfer a 6" from the rotary table to my lathe. So basically, I'll need two chucks for each machine.
                    franco
                    Does anyone here use a dividing head with a mini mill?
                    I'd appreciate experiences and recommendations.(I need an idea of what to keep my eyes open for).
                    Thanks a lot.
                    Darren Harris
                      I don't yet but I'm going to. The advantage is the various compound angles you can work with vs the rotary table. You can, for example, make a bevel gear. My only problem is I don't have a need for it so I can't explain the purchase to my wife with a straight face.
                        Lateral thinking
                        Not necessarily so Dennis.
                        While a dividing head tackles bevel gears by tilting upward it needs a horizontal tool arbor - as on a horizontal mill.
                        You can achieve the same result with a vertical mill and a rotary table. The cutter is put on the vertical arbor and set that the rotary table centre height and the rotary table is set vertically and its axis rotated left/right as the dividing head axis was rotated up/down.
                        The cutter is set over the job axis on a dividing head but is set to the side of the job on a rotary table.
                        The actual orientation of the job and indexing device in absolute terms on the one hand and the position of the cutter on the other hand is not as important as the relative orientation of the indexer and job on one hand and the axis of the cutter and its arbor on the other.
                        In short, it is both quite possible and practical to cut bevel gears with a rotary table set vertically and the cutter arbor axis set vertically - as will be the case on a vertical mill.
                        I have never needed a dividing head as I don't have a need for a universal (horizontal) mill.
                        If I need to tilt the job axis relative to the arbor (vertical) axis I either tilt the milling head or mount the rotary table on a tilting angle plate.
                        Simple and compound angles are very easy to set. I used a 0.1* (6 arc minutes) digital protractor/bevel guage to set these. If I really need more accuracy I will use my precision angle blocks.
                          I may have a learning opportunity here. I was thinking that Sir John's "D" bits would do the trick. Cutter example: http://www.youtube.com/user/John5tev.../7/fps0OR1eF_s
                          In the case of a bevel gear, the head does not rotate, but is tipped up appropriately.
                          It (the dividing head) would also have to be swung at the convergence point of the bevel so as to cut both sides of the bevel. For that it would sit on a plate that pivots on the table.
                          I should probably draw a picture.
                          The other thing is, my mill doesn't have enough head room to put my rotab on a tilt table. Some day...
                            Eureka!!!!!!
                            Dennis.
                            The rotary table on a vertical mill only has to be set vertical and rotated left/right the same angle that a dividing head on a horizontal mill is tilted upward so you should be better off with a rotary table which will or may require less head-room than a dividing head.
                            The cutter is set to the side (back or front) of the job centre (which is horizontal) will gain quite a bit of head-room as compare to that of a dividing head where the cutter is over the tilted job and dividing head.
                            The dividing head vertical axis is set to the horizontal when a rotary table is used.
                            Think about it.
                            I am sure that there will be a Newtonian apple (penny?) drop and the "Eureka" ("I've got it") moment (sorry - couldn't resist it) will arrive:
                            http://en.wikipedia.org/wiki/Eureka_(word)
                            http://en.wikipedia.org/wiki/Eureka_effect
                            "light bulb moment"??
                            http://www.google.com.au/#hl=en&sour...f291d940157105
                            Tell your wife that you no longer need or want a dividing head and she will be so pleased with and proud of you!!! - which of course, being the modest chap that you are will agree with fulsomely as you apparently defer to her new-found regard and esteem that she has (will have) for your assiduity and diligence and your very good graces in ample form.
                            http://en.wikipedia.org/wiki/Assiduity
                            http://en.wikipedia.org/wiki/Diligence
                            If it all goes pear-shaped, blame "that ba$tard tiffie" - and "why not" you say and say I.
                            You are on a winner here Dennis.
                            You wish!!
                              Ok. Like I mentioned, I do have a mini mill/drill. So it comes down to figuring out what I can do within the work envelope.
                              I don't even know if I have enough room for my rotary table, which is 3.11" in height, to fit on a tilt table.(Though I am considering getting this: http://www.grizzlyindustrial.com/pro...w-Clamps/H6195
                              So if not a dividing head, then can I get recommendations on a tilting table?
                              Thanks.
                              Darren Harris
