History of vertical mills
  • History of vertical mills
    Is there a book that tells of the history of vertical mills? I read, or heard, once that vertical mills were developed to mill trigger guard for rifles in government arsenals. Is this really true as I can see how a Shaper could NOT easily do that sort of cut and it would be difficult on a horizonal mill.
    There is not really much that a vertical mill can do that cannot be done on a horizontal mill with an angle plate.
    I don't know when the vertical milling machine came into existance, but it was preceded by vertical milling attachments for horizontal milling machines.
    Bridgeport started in the business making heads for this purpose. In the mid-late thirties, they made the base and developed what became the turret milling machine.
    Jim H.
      Al if you can get from your central library system, a book called History of Machine Tools 1790--1910 by Steed, It is a British publication, It tells of the development of the milling machine, Another is Tools for The Job by L T C Rolt Some of rolt tells of the American small arms production, which brought the vertical milling machine to a high art.
        I've heard that the first Bridgeports were developed for patternmakers and later applied to metalworking.
          There is quite a bit of info here: http://www.lathes.co.uk/bridgeport/
            Vertical mills were about years before Bridegport stuffed the design up.
            From 1916.
              From 1916.
              Do you have a pager that goes off when the word "Bridgeport" gets typed on this forum?
                I wondered about that too.What`s he got against them.:-)
                Mark.
                  Mark.
                  Or more to the point, why doesn't he replace his with a TOS or Beaver or Ramboudi or round column mill drill, etc etc.
                  Precision takes time.
                    And then what would he have to whine about??
                    Ernie (VE7ERN)
                      Because it's going to cost me a whole weeks lost production to get this POS Bridgeport out and a TOS or Ramboudi in.
                      Quickest way would be to get the roof off, hire a 70 tonnes crane for the reach needed and lift them in and out, then put a new roof on.
                      I may even do this in a couple of years when I start downsizing, the big TOS lathe that is in the way will be one of the first machines to go.
                      It attracts the wrong sort of work, rotors weighing 3/4 of a tonne, you have to crane in and crane out.
                      I can earn the same rate as something I can hold in one hand so why the hassle
                        I do not often post links, but here is one I found while browzing: www.lindsay publications.com. They have tons of re-printed machine shop and etc books for sale at very reasonable prices.
                          The vertical mill was invented by Harbor Freight in 1973. End of discussion.
                            Here's the link http://www.lindsaybks.com/
                              Originally posted by Dr Stan
                              He's correct---I blew it!!
