Help Me Build This Thing...
  • Help Me Build This Thing...
    I can visualize it in my mind.
    The part is an insulator. It has a central fiberglass rod over which I put a thick rubber material. The very ends where the rod protrudes needs to be deflashed.
    I can do that with a hollowmill. I do not want to tie up my lathe with this job so...
    Somehow I need to attach that hollow mill direct to a motor that will be actuated with a foot-switch. It is one of those motors with a brake drum attached. Stomp on the switch it goes VOOM then take your foot off it stops.
    The hollow-mill is a #2MT (short) shank... I need some way to attach this directly to the motor.
    I assume that they sell chucks or adaptors or some nonsense like that... Something that goes over the motor shaft so I can mount the shank... but I don't know what to call it or where to source it.
    I am working on the fixture/positioning system separately. The motor with the hollow-mill will fit on this.
    Plastic Operators Dot Com
    For a tool holder on the motor you could just find a MT2 tailstock ram and bore it to fit the motor shaft.
    Monarch 10EE 1942
      I thought of that moments after I posted this. I can order an entire tailstock as a "spare part" from Little Machine Shop.
      ...and now that I'm looking at it my hollow-mill can be detached from the shank... somehow. I should contact Genesee Tooling before I wreck it.
      Thanks for the idea though Peter.
