More facemill exercises. Make you own for a buck.
  • #46
    Not yet but it will work just fine. This isn't the first such tool I have made. I make most of my tool holders with the exception of collets. There are many ways to skin the cat. A fly cutter type of tool is nothing more than a lathe bit that rotates instead of the work. You can recycle worn out end mills by grinding the end in the approximate shape of a regular lathe tool lying horizontally with some relief. It will do a very nice job of taking light cuts.
    • #47
      I expected as much but -had- to ask!
      The fly cutter I use in my little benchtop mill has never done a satisfactory job IMHO. That is a good size for the material I work with mostly. Thanks for the post!
      Mike N
      Occasional maker of swarf.
      • #48
        Originally posted by PaulT
        I would suspect its probably case hardened in the seat area, if you think about it there's no reason to do any more than case hardening on most tooling. But as I stated earlier, its still surprising how much high end tooling is not made from a particularly hard steel or even has case hardening.
        Paul T.
        It may be easier to just make it out of a hardenable tool steel and heat-treat the whole works. Case hardening isn't really so much easier than any other process.... it used to be a lot cheaper, but these days the process time likely costs as much as material is cheaper.
        I have a Sandvik cut-off tool that I needed to trim the shank of, because it was a size too big for my toolpost (5/8 instead of 1/2). That thing was harder than the hobs of hell, and it was hard right through.
        • #49
          Just saw this thread - glad to see I'm not the only nut making bits from bolts. Mine was a quick one-use wood bit, turned on the mill and hand filed but not hardened:
          It's posted as a quick part of a long repair "blog" - -
          http://www.frets.com/FRETSPages/Blog...8/37d28_1.html
          Frank Ford
          HomeShopTech
          • #50
            Are you guys not concerned with the bolt threads damaging your collets, or have you removed the threads?
            • #51
              They don't damage a lathe chuck. A collet clamps near the opening with little force much past that.
              • #52
                If you are concerned about the threads, why not get a long bolt and cut them off...?
                • #53
                  Not me. You may notice that my bolt is just a regular one, not hardened.
                  Frank Ford
                  HomeShopTech
                  • #54
                    That would booger an ER type collet if gripped on the threads....
                    Mike N
                    • #55
                      Right. See my post # 52.
                      • #56
                        It would do and even better job if it spun
