convert sandblaster to baking soda blaster
  • convert sandblaster to baking soda blaster
    Must be getting senile. I thought i had posted this but???? anyhow couldnt find it (the post I thought id made) i wanted to use my sandblaster with baking soda what type of changes should be done to enable this? Thanx Mike
    Empty out the sand.
    Fill with Baking Soda
    "...do you not think you have enough machines?"
      Here's the thread I found on the Hot Rodders forum
      http://www.hotrodders.com/forum/soda...ap-128088.html
        here is your other thread
        Glen
          Damn going senile I knew it
          Yeah must be going nuts. I did use the search feasture on the hSM site as i thought i had already posted this but couldnt find it. My computer is phasing in and out a LOT with the screen going almost black then back up again and so on. Might have something to do with posts?? Hope so. Anyways thanx Appreciated Mike sorry biout the double posting I apologize'
            bad link
            The Eastwood link to the conversion kit is broke.
            What I want to know it:
            What does the conversion consist of?
            Will soda blasting remove rust? No mention of rust removal in the Eastwood material
              I found and downloaded the instructions.
              What about cutting rust?
                try here: http://www.eastwood.com/soda-blastin...o-fit-kit.html
                  It doesn't remove rust, it is for paint and grime removal only. IT is a mild abrasive. It is not a cure all,
                  Here is the other thread with dry ice removal link
                  To remove rust to bare metal you will have to use some form of a more aggressive abrasive media.
                  Glen
                    Soda blasting can have issues with the painting process if not removed totally before painting.
                    Looks like the kit major difference is the purge hose to free a clog. If I find time I will try to throw together some parts for my pressure blaster to try. That find some time my be some time from now. ED
                    Ed
                    Agua Dulce, So.California
                    1950 F1 street rod
                    1949 F1 stock V8 flathead
                    1948 F6 350 chevy/rest stock, no dump bed
                    1953 chevy 3100 AD for 85 S10 frame have a 4BT cummins motor, NV4500
                    1968 Baha Bug with 2.2 ecotec motor, king coil-overs,P/S
                      My little sandblaster loves to make water at the nozzle in humid weather. I can imagine the clogs trying to use baking soda. Don't commercial sized units (that work) have a refrigeration system to dry the air?
