Deep drilling 303 stainless steel
  • Deep drilling 303 stainless steel
    Looking for some advice...
    I have a few lengths of 15mm diameter 303 stainless rod and i need to drill a 9mm hole into the end about 80mm.
    I'm looking for any recommend speeds / feeds / cutting oils / words of wisdom / etc...
    Cheers
    Batt
    Slow speed, about 400, heavy feed, bags of coolant, flood not drip, sharp tool, preferably a brand new cobalt drill.
    NEVER let it rub.
    303 is the best of the stainless to work, turning and milling with tipped tools is a dream, it's when you drop down to normal tools like drills and taps in HSS that gives problems but 9mm going 80mm deep in 303 should be a breeze.
      search this forum in thread titles "deep hole drilling"
        deep hole in 303
        I would use a parabolic drill . They tend to push the chips out.
        Jim
          Jim
          Funny you mention that:
          GW suggests when you should consider a parabolic, JS is right on the mark for rpm, and you can see a suggested feedrate there on the screen shot. Peck drilling is also reccomended.
          BW
