metric seal for coolant pump
  • metric seal for coolant pump
    Hi Guys! My coolant pump was leaking thru the weep hole the other day.
    I bought a new one but would like to fix my other spare pumps. there are 2 bearings (6200z) Found them on Ebay for a few dollars each. I can not find
    the seal (google search) It is 25 mm od x 10 mm id x 7 mm long (KCM printed on seal) ...... bummed out.....any leads? Thank you very much...Dean
    www.neufellmachining.com
    Go to any Napa store. They can cross reference it to some very common part numbers - they will likely have several alternatives - you'll have to decide the seal constuction/lip type etc.
    Any bearing house will likely have it in stock also.
    If you are searching online, the size is 10x25x7 - order is important. A simple search on this returns many possibililities.
      Thanks Lakeside53.....I try the NAPA guy tomorrow....hopefuly they will have
      a cross ref.........Dean
