How to keep mice out of the coolant tanks
  • How to keep mice out of the coolant tanks
    Mice are constantly drowning in our coolant tanks, any good suggestions on how to keep them out other than going to oil based coolant?
    Have you considered supplying tiny life preservers?
    TMT
      Don't use booze as a cutting fluid.
      Southwestern Ontario. Canada
        Throw a cat in the tank.
        Plastic Operators Dot Com
          Put paddles on the wheel of the tramp oil skimmer to scoop them out.
            Couldn't you screen the tank opening? or place a stick in the tank to the top edge of the coolant tank and the mice can crawl back out.
            Jim Doherty
              You need a shop beagle.
                I seem to recall a thread touting the benefits of rodent-fortified coolant fumes not that long ago.
                One benefit is you'll spend less time machining and people will stop bothering you while you work
                  Dont keep mice!
                    Put up warning signs
                    Oh, that's right, mice can't read....
                    No good deed goes unpunished.
                      Wire mesh?
                        Don't use Kool-aid, it's not a coolant.
                        Lee
                          Add some sulfuric acid to the coolant.
                          Rendered fat is a great lube
                            They can't dance either....that's why they have such small balls...
                              How to keep mice out of the coolant tanks? Set up a beer tank.
