Newbie tool gloat
  • Newbie tool gloat
    Just a couple pics of some of the new toys I have managed to add to the hobby. I have to try to keep the $$$ down so I usually get iron that needs a little TLC.
    Kalamazoo horizontal band saw - parts not shown but present include coolant pan and pump. Works, just needs cleaning and assembly. $75
    Powermatic 20" drill press - needs 1-1/2 hp, 120vac, 1-ph motor. Found a new, surplus motor for $150. FREE, buddy at work had it for several years and never got around to restoring it.
    Coffing 1/2 ton electric chain hoist - found on CL listed as engine hoist. Got hold of Coffing and had them to send me a manual for it. Finally figured out how to switch over to 120vac operation. Works great. Will look good hanging from my gantry crane when I finish with it. $120
    Nice score . Does that Powermatic have power down feed?
    I have one at the shop that someone dropped or knocked over that I have to get around to some day, oh and they tried to cut the table in half by line drilling it
      No power down feed. But still a huge step up from my little B & D tabletop DP.
        nice score, you should buy a lottery ticket. it is nice to see good american iron go to a good home instead of the scrap yard
          Yes, all good tools, three nice scores, you must be pretty happy
          I really would like to get a saw about that size as well.
            I have more , just no pics yet .
              Nice, that bandsaw looks like it will last you forever. And you don't need to worry about the coolant rusting it... :P
              But more seriously, bandsaw = best at cutting metal, WAYY better then those abrasive cutoff saws for mild steel. And cuts aluminum like a hot knife through butter.
              Keep the abrasive saw somewhere incase you need to cut something hardened (HSS?) but otherwise.. bandsaw all the way!
