I've been toying with the idea of a tapping arm for a while. I know some people are using inline impactors and such but I have a small tapmatic head and it got me thinking. Could I use an air drill with a 1/2" chuck (for the 1/2" shaft on the tapping head) and make that work at the end of a tapping arm? Anyone ever tried that?
ever heard of air drill + tapping head?
Originally posted by DaHuiI've been toying with the idea of a tapping arm for a while. I know some people are using inline impactors and such but I have a small tapmatic head and it got me thinking. Could I use an air drill with a 1/2" chuck (for the 1/2" shaft on the tapping head) and make that work at the end of a tapping arm? Anyone ever tried that?
At princess auto, they have some awsome air over hydrolic (???) screwdrivers that look like they have enough torque to tap..Play Brutal Nature, Black Moons free to play highly realistic voxel sandbox game.
I have a German (can't remember the brand) pneumatic air drill -- it has a planetary and spring loaded clutch, and it's got way more torque than a battery-powered drill. I'm pretty sure it would have no problem tapping.
I think that's what the professional pneumatic tapping machines use."Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did."
Air-powered tapping head
John Stevenson has a very good air-powered tapping-head on a partial pantograph linkage fixed to his work bench.
John was pretty pleased with it as it really did get through some work.
I don't have a link to the post/s but others may have.
Tapped
Originally posted by oldtiffieJohn Stevenson has a very good air-powered tapping-head on a partial pantograph linkage fixed to his work bench.
Here ya go.
I hope it helps.
If someone can post the link/s to John S's tapping head the text will assist a fair bit as well:
Yeah I saw John's a long while back and that planted the seed in my mind. I know Bob Warfield has also done some musing on a similar design. Unfortunately I don't want to drop the crazy amount of money it costs for one of those air tapping heads...especially since I have a tapmatic 30x lying around.
If I could use a 1/2" air drill I could just chuck up the tapmatic and go for it. It seems like 1/2" air drills have relatively low rpm (500-700ish) and that is great for the tapping head. It says it can go up to 2000 rpm but the idea makes me a little jumpy
Any idea how easy it is to remove the 1/2" chuck? I would be nice to shorten the overall length of the drill + tapping head but my 30X has a 1/2" shaft on it so maybe it isn't worth the bother.
Good to know there should be plenty of torque so I might try to find a good deal on an air drill.
FWIW, I used to manuf these machines...
You need an air drill with reverse button. 400 rpm will get you aprox 1/2 NC capacity in mild steel, 600 RPM=3/8 NC cap and 1,000 RPM= 1/4 NC capacity.
Ideally you want Bilz no. 1 tap chuck for the driver, but you can configure a typical flex collet chuck if doing it on the cheap....you just won't have the quick change capability and overload clutch of the Bilz holder system.
The professional systems use a tapered shank on the air drill to affix the tap chuck, but you can get by with the typical threaded shank if you are careful to thread the tap chuck pretty tight. You will also need to have a small tapped hole in the side of the chuck so you can apply a set screw into the air drill shank to keep the chuck from unthreading in reverse.
Tap-'n'-go
Following on from Millacrom's post.
David, here is an idea of the taps and speeds required:
I use the "gun point" taps and as my tapping heads have an adjustable clutch and as I am retired and all of my work is a "low number off" on an occasional basis, they do the job just fine. Mine have MT3 tapers for use in my mills. I keep to pretty low speeds but the low speed torque is handled by the clutch in the tapping head.
A good drill on a good portable stand should see you right as you can take the machine to the work or leave it on the bench:
