newb shop is spinning up slowly
  • newb shop is spinning up slowly
    My birthday is coming up - I'm looking for generally useful tools.
    There's this:
    combo disk and belt sander
    which if it will accept disks and belts suitable for metalworking looks interesting.
    And there's also the tried-and-true horizontal bandsaw...
    Or a little drill press.
    My current tools include a typical bench grinder and a old lathe that barely works
    Any other suggestions?
    You hinting at wanting a Birthday present? If so it would be a good idea to post a location. I'm not shipping a machine across the Country.
      No, I'm hinting I'm going to buy myself something, likely at an importer of barely adequate Chicom goodness!
        resist, no seriously, everyone does make fun of the cheap crap, but it does give you the oppertunity to learn, all be it the hard way, and when you do get some tidy iron oh it feels great, i had a really crappy small mill, then i got the chance to get a cincinatti toolmaster from work, my missus went bonkers as it was in the middle of the drive!, she knows i'm a bit batty so she only asked that i move it, right now, oops the car wont fit in the garage anymore.
        when you first stick a 6" cutter in somthing like that and take a cut on a nice lump of steel to reveal shiny shiny flatness its great.
        Good luck, i hope you have a long and satisfying affair with iron, i have and its the best thing since sliced bread.
        mark
          if you're prioritizing, probably the bandsaw but the drill press is a close second. True, you could hacksaw everything but you might not last until your next birthday and you can drill holes with the lathe
            Bandsaw,a servicable machine even from HF,the belt sand and dp pictured are crappy.
              Get the bandsaw. Every project you do starts with cutting off a piece of something.
                I will second or third the bandsaw. You will wonder how you got by without it once you have one in your shop. They are great at saving time and your arm. Just do yourself a favor and buy the bi-metal blades, the standard metal ones will burn up in a few hefty cuts and end up costing you more in the long run.
                  Tony,
                  Another vote for the bandsaw, they are really handy around the shop.
                  What kind of lathe do you have? You say it is crappy, how come? Will it make chips? Pictures man!!
                  Instead of a drill press, you might want to consider a small (or large) horizontal mill. They are very versatile and can be pressed into service as a very accurate drill press in a pinch
                  Tim
                    What does that mean "Chicom"? Is it Chinese Commercial ?
                      No shop is complete, unless you have one of these:
                        OK KiddZimaHater,
                        I'll bite. WHAT IS IT?
                          There's this:
                          Not a comment on quality or lack thereof, but the link to that belt/disc sander lists a disc rpm of 1720 which makes the grinding a real grind, especially with a 9 inch disc.
                          I don't know what the belt fpm is on the belt/disc sander that I have had for 15 years, but I am fairly certain that the 12" disc is running at 3450 rpm. It is a direct drive off the motor shaft, one side for the belt, the other for the disc. I know they were available in both 1750 rpm and 3450 rpm and the slower ones were a real dog.
                          It is a little down on power for sharpening a 2" or 3" twist drill, being a Harbor Freight variety, but I guess I got lucky as I haven't yet let any/all of the magic smoke out yet.
                            You need to read the post, "What is this?"- by Wavedude
                              I would suggest the drill press first and hacksaw until you have enough money for a horizontal bandsaw.
                              Forget the belt sander: when you eventually get a belt grinder, you'll want a 2" belt anyway.
                              The drill press situation these days is pretty sad: you're going to find the same Chinese drill presses at Harbor Freight, Sears, Lowes, Home Depot...
