Mitee Bite and Gibraltar fixture clamps.
  • Mitee Bite and Gibraltar fixture clamps.
    So I ordered from Enco what I thought was a great deal. 2 sets of Gibraltar surface fixture clamps for $8.00. The picture included the screws in the ad. Turns out I only bought the hexagonal washers, no offset screws.
    That being said, does anyone make their own offset head screws? Is there a cheaper version of this magical screw? I do not need 10 screws for $35.00 and I can't find any place that sells single screws, or sets of 2. I can't justify paying $3.00 a screw times 10.
    Any help is appreciated. #8-32 screw is the size in question.
    Just stick a SHCS in the 3-jaw with a spacer on one jaw for the offset and turn it down. I have made a few and it didn't take any time at all. I don't remember exactly what I used for the spacer but it was around 20 thou or so.
    Edit: Mitee Bite clamps use button heads, looks like Gibralter uses socket heads. The button heads would allow for a larger offset.
    "Work hard. Tell everyone everything you know. Close a deal with a handshake. Have fun!"
    -- Harold "Doc" Edgerton
      I'll try it, thx. But do I need and independent 3 jaw chuck? Mine is not independent.
        Confused!!
        Do you really need an Independent 3 Jaw to do this??? Isn't the shim there to give the desired offset using a normal 3 jaw chuck?
        Rgds
        Michael
        Australia
          Either a 3-jaw with a spacer or independent 4-jaw will work. Whatever will give you an offset. Do they even make an independent 3-jaw?
            There was a well done tread on DIY mitee bite clamps on here or maybe PM 2 or 3 years ago.
