Ot F150
  • Ot F150
    Anyone tried to change spark plugs in a Ford F 150? Backyard mechanics move over.
    Yeah, I changed the plugs in my 1975 F150.
    It was pretty easy.
    Move over where?
    --Doozer
    DZER
      I had a 1990 with the six that unscrewed the plugs itself.
      Jim H.
        By themselves?
        What could me easier?
        --D
        DZER
          Thought about it until I realized I would have to lay across the radiator to even be able to reach the ones in the back. Decided paying my mechanic was a better option. BTW - The Ford shop manual for a 2001 says the job should take 1.5 hours.
          Steve.
            I feel your pain. I'm midway through swapping an '05 4.6l romeo into a '98 4.6l windsor. Pulled the plugs for the compression and leak down tests though.
            Don
            If it wasn't done the hard way, I didn't do it.
            Lillooet
            British Columbia
            Canada.
              Took me 1/2 hour to do the plugs two weeks ago on my 92- F150
              Did I mention its a straight six ?
              Rich
                try 2010 V8 then I'll move over
                  First set is the toughest. Don't forget to replace the spark plug boots. I always use double platinum plugs. Get a nice thick pad to protect your ribs and belly. The back 2 on the pass side are the worst...........
                  best of luck, TC
                  Oregon, USA
