Air compressor outside?
  • Air compressor outside?
    Good idea, bad idea? Let's say one of those 80 gallon vertical units, bolted down to a concrete pad. Have to put some pipes and wiring thru the wall. Sound abatement, rain, sunlight, = build an enclosure? or maybe surround with bales of hay?
    Semi-rural area. Neighbors probably 60 yards away.
    Thanks,
    Gary
    Gary
    Appearance is Everything...
    good idea just dont ignore it.
      If you live in the Frozen North, icing up might be a problem in the winter. If it gets really cold, synthetic compressor oil might be a good idea, too, so the motor doesn't bust a gut on a frigid morning.
        I'd build an enclosure if my neighbors were only 180 feet away. Another option -- assuming it's something like a Quincy with a piped inlet filter -- keep the compressor inside but pipe the air inlet and filter outside. Cuts the noise inside considerably. Not quite so annoying for neighbors.
          Air Compressor outside.
          For me it was a good idea. My neighbors are 300 yds away so they don’t hear it. My patio is 60 yards away and I do hear it but it rarely runs when I am using the patio. This shows my installation next to the old barn.
          My shop is about 65 ft away. I can still hear it run but it is not annoying. The blast cabinet is in the old barn when the rollup door is open it is still noisy. Here in central Texas it doesn’t get cold enough to be a problem with it outside. I have an extended drain valve that makes it easy to drain moisture on the way to the shop. My compressor is not bolted down just setting on some rubber pads.
          Byron Boucher
          Burnet, TX
            Mine's outside. It's a Champion light industrial unit. By the time it rusts out due to weather exposure, I'll be compost.
              Doesn't anyone separate the compressor unit from the tank?
              This makes it easier to isolate the noise maker in a smaller enclosure.
              Eliminates any resonance from the tank and the tank can be kept
              inside where it may be less subject to ambiant temperature variations
              and condensation arising from same.
                You can just take the compressor and motor off the tank, and mount them on a separate base. I have to do this in my barn attic because of head room. The tank doesn't need to be inside - a decent coat of paint will stop the tank rusting on the exterior.
                  Course, you gotta plumb the compressor to the tank with copper or similar high temp materials.. And keep the line away from flamables.
                    Condensation on the inside of the tank is a consideration.
                    In my climate, temperatures vary from below -40؛F to +100؛F ambiant.
                    Direct sun in mid winter frequently causes thawing in sub zero temperatures.
                    Stabilizing the tank temperature where possible helps contain moisture
                    accumulation.
