My first sprocket
  • My first sprocket
    I need a couple of sprockets for my shearing machine. This is the first one!
    It is only the rendered drawing so far.
    it doesnt look right to me ..
    the prongs should be higher
    http://www.google.co.uk/images?hl=en...iw=767&bih=374
    all the best.markj
      You'll get them cheaper at www.maedler.de And they even fit the chain.
      Nick
        Yea, Toothform looks wrong. Allways get a book for the numbers when making spockets/gears/etc.
          Yes I know. All the dimensions are wrong. I was just trying to figure out how to make the teeth, any teeth! Now I can model the correct dimensions.
            Originally posted by Black Forest
            ...I was just trying to figure out how to make the teeth, any teeth!
            http://www.gizmology.net/sprockets.htm
            http://idleamusements.com/sprocketeer.htm
              Sprocketeer is the one to use.
              It makes them like this including the gcode.
                thanks for posting that sprocketeer program, it is nice and easy to use.
