Forklift forks
  • Forklift forks
    Do any of you folks know what kind of steel is used to make forklift forks?
    The reason I ask is that I just ordered a new set of forks that are a foot longer and will have two old forks to use for wharever.
    Evan: I made the phone calls to the actual factory in Guelph Ontario and was reassured that they are indeed made in Guelph or Lima Ohio. Everything is NOT made in China as some people think!
    That way they can slap a ''made in the USA'' sticker on the import fork lift.
    Not sure what steel is used but the tapered tips make nice wedges that come in handy on all sorts of projects.
      They are made of different types of steel. Sometimes HSLA A572-50 (high strenght low alloyed) steel, 1045-1060 heat treated material, T1 heat treated steel and others. May or may not be weldable. Sorry, may only be good for counterweigh or similar.
        Good forklift tines are made from 4140 and 4340 -- great material.
        The only reason I know is I've been dumpster diving for anvil materials, and several of the local blacksmiths tell me forklift tines make great anvils
          Ditto Lazlo. Chrome Moly
            Used forks here are worth $100/fork for ITA mount and $150-300/fork if they are rod mount depending on size.
            Or you could cut them up
              Yah, I was looking for one that was crashed or worn out, so I could plasma or flame-cut a 1 foot section off it.
                Could you expand on how you use the tips for wedges?
                I am always looking for another project to make.
                Thanks
                TMT
                  That may be hard to do.
                  Many yards now will not sell any used fork, complete or partial, because of liability.
                  TMT
                    Bummer. They apparently work well as a poor-man's anvil:
                      Home made Anvils
                      That was interesting. I recently saw a small anvil someone sculpted from a piece of Rail Road Rail. It was small but reflected some real talent. Would a larger piece of rail upside down work like the fork lift tine? I posted this a while back but I mounted my anvil on a piece of 12 3/4" well casing and filled it with concrete. It is heavy and stable but it is easy to roll/walk it around.
                      Byron Boucher
                      Burnet, TX
                        Originally posted by marquejohn
                        Steel forklift forks are the answer to all problems. I have a couple of them but am not sure though whether the steel used is HSLA A572-50 or not. I particularly don’t care if forks are made in China or not, as long as they are good quality and durable!
                        Nice spamming, please get your things and get out.
                          What a dick-wad.
                          He's selling forklift forks and he doesn't have a clue what they're made of!
                          Yeah give me a dozen of those.
                            I use a couple of pieces about a foot long milled and surface ground parallel and equal thickness for work supports on my hydraulic press. I know they aren't going to bend or break.
                              huh? did I miss something? this thread is three years old!
