Clausing Tailstock Wrench
  • Clausing Tailstock Wrench
    Does anyone know where I could fine the original tailstock wrench for a clausing 6300 lathe?
    When you say "tailstock wrench", do you mean the one to tighten a nut to clamp the tailstock to the bed? I can't really think of any other wrench that you might use on a tailstock.
    Wouldn't any wrench that fits the nut do, or am I miles off?
    Ian
    All of the gear, no idea...
      wrench
      yes it is the wrench that tightens the t/s to the bed, any 7/8 regular wrench works but not alot of room the original hooks on the bolt to allow it to pivot back and forth on the nut flats.
        This is the "dedicated" wrench you are referring to I suppose? I have one, unfortunately it's attached to my 6329 TS. Have you checked with Joe B at www.plazamachinery.com?
        I bury my work
          wrench
          Your right it is the dedicated wrench, I contacted Joe at plaza he has nothing right now.
