Knurl pitch: in industry, how specific are knurling spec's on print
  • Rich Carlstedt
    All the above are correct
    Knurling is a non-precision operation and as such few 'controls" are of value
    When precision is required, a "Machine cut" pattern is spelled out and then you use a (powered) indexer and milling cutter. Fortunitly, This is seldom !
    Such a call out gives ID, OD, pitch ,LOC, Cutter Profile to use, and sometimes the sharp edge radius (!)
    As such, the only drawing I can recall was for steel drive roller which fed oily steel blanks into a punch press. It looked like a simple knurl, but the dimensions were tightly controlled, and the profile had a Buttress thread appearance
  • ckalley
    We have parts where I work now that are knurled. On the drawings they call out the pitch of the knurl and the style - "25 pitch straight knurl" for example. Also, we have some parts that are knurled for a press fit and they also have a tolerance on the OD after knurling.
    Other places, that were less 'formal', would just call out something like 'medium diamond knurl'.
    Craig
  • TGTool
    We always just called out "knurl" and let the toolmakers apply whatever they thought worked best. I never saw anything more specific on any tool drawings I ever encountered.
  • Arthur.Marks
    To clarify: which is standard practice?
    * Diamond Knurl, medium pitch
    * Diamond Knurl, 30tpi
    In other words, calling out "medium pitch" allows you to use a range of similar pitches, whereas the latter specifies an exact pitch to use.
  • Knurl pitch: in industry, how specific are knurling spec's on print
    For those with industry experience:
    How specific is "standard practice" WRT knurls. How many prints call out a specific pitch figure---and not just diamond, straight or cross?
