question about morse taper
  • question about morse taper
    http://www.diracdelta.co.uk/science/...er/source.html
    What does 'half included angle' mean? An example is " 1deg 28' " Why is it measured in degrees-foot instead of just degrees? I'd like to find out the angle of a morse taper #3.
    "Half included angle" means the angle of ONE SIDE of the taper.
    Angles are usually measured in degrees minutes and seconds as in this case. There are 60 seconds on a minute and 60 minutes in a degree.
    Angles can be measured in other ways - in decimal degrees, in grads (400 to a circle) in Millieme (640 to a circle) and others.
    The taper of one side of a #3 MT is 1 degree 26 minutes 15 seconds (1 deg 26' 15"). This is the angle you would set your compound to if machining the taper with the compound.
    "Patriotism is the last refuge of a scoundrel"
      Morse #3 Taper
      Morse #3 Taper -----.60235 inches per foot.
        Yup. Mr Morse made the Morse taper gages and they are still used as reference masters. They had slightly different tapers then and they till do now.
        The accuracy they were made to was pretty good for 1843 or whenever but these days we usually specify fancier stuff. That said the very fact the Morse taper series endures is a prime example of de-facto industrial Darwinism ie: firstest with the mostest.
          Tapers - various
          Try these - Morse Tapers (MT) is among them:
          and:
          http://i200.photobucket.com/albums/a...ine-taper5.jpg
            deleted double double post
            Tom C
            ... nice weather eh?
              Hi Elninio
              pretty sure that is just measuring angles in degrees, minutes (') and seconds (")
              so that 1deg 28' is just shy of a degree and a half
              1 + 28/60 ~` 1.46666 degrees
              Tom C
                deleted double post
                Tom C
                  thanks everyone
